My KEF 3005SE Setup - Pics
I'm so glad I got these instead of the Kef AV50 package after seeing them both in the flesh. Not to keen on the new white ones though
That girly look doesn't do these little beasts justice
Agree, dont like the white ones. Not sure who would buy these unless they got a white tv..
My subwoofer setting is on -12 at the moment as the wall its up against is the neighbours. Still sounds amazing though.
Cant wait to move out now and crank these badboys up!!
Hems:where did you get the equipment rack from?
It was just a cheap one from Argos - Not sure if they still sell it now. Was around £50.
Im going to change it soon though as I want one with cable management as it a bit messy behind the unit. Plus cant fit the Receiver in the shelves because its not wide enough which is why its on top at the moment.
Nice set up - I'd try the centre below the screen for better cohesion across the front soundstage?
The lightshade on the ceiling - is it windchimes? I'd also take the Sony off the amp - would imagine a fair bit of heat up there?
Cheers,
Cofnchtr.
Hi, thanks for the advice
Cofnchtr:I'd try the centre below the screen for better cohesion across the front soundstage?
It is currently on top as I may be moving out soon (currently live with mom and dad) so have not bothered to put the bracket up.
Cofnchtr:The lightshade on the ceiling - is it windchimes?
Its like a "cheap" chandelier..
Cofnchtr:I'd also take the Sony off the amp - would imagine a fair bit of heat up there?
This is just a temporary measure until I get a new equipment rack - The current one is not wide enough to fit the receiver otherwise would have it on the bottom shelf. Usually the player is pushed right to the back as not to block the vents on the top of the denon (I just pulled the player forward for the pics) as I too was concerned with heat issues.
Kris
