Musical Fidelity XA-2
roym90
39
One of these was mentioned in a topic I put up the other day. I have just seen one going for a good price
Wondering what your opinions on it are, I've seen a few old posts and people seemed to like it.
I would be pairing it with Monitor Audio RS5s
Thanks for any feedback
richardw42
299
I say Buy It !!!!! These are awesome amps. I so regret selling mine. No remote. Build is so solid too. It worked well with my RS6s and even better with some B&W CM7s I had.
roym90
39
Thanks for the reply,
I'm glad you said it worked well with the RS6s! Been wanting to improve the RS5s without spending too much for a while now
I had one for a few weeks and it was pitted up against a Cyrus 8VS2 and a NAD C352 amp with some B&W CM5's and a Rega Apollo and iTunes as the sources
Findings were:
MF X-A2 - Great amp; very well built (farily light though in comparison to the other amps). Great, detailed and open soundstage but bass was a bit light at times and the overall sound was too smooth with the B&W CM5's (also smooth sounding speakers IMO so probably not the right combo).
Cyrus 8VS2 - Superb amp; built like a brick and sounded fantastic. A little bright at times but the smoothness of the CM5's calmed this down. The bass weight was superb; deep and punchy but well timed and no lag
NAD C352 - Solid amp; built like a battleship and sounded amazing. Bags of power on tap. Overall soundsatge similar to the Cyrus but not as bright. However bass was a little too much at times.
If you want to calm the RS5's down then I'd say the XA2 would be a great amp to go for; more so if you can get it at a good price.
Buy it, see my profile pic, a former x-series owner, great amp.
I have also used a cyrus 8vs and a nad c352, both good but the xa2 the is best sounding imo, smooth, detailed and nice solid bass.
roym90
39
Well I tried to buy it! But after that last minute bidding I obviously wasn't the only one watching it.
My other second hand option is a Creek Evolution, which was also mentioned to be before as a possible match. Any views on this one if I don't wait around again for more options to come up?
Thanks again for all your help.
Creek Evo is a good amp so would be worth taking a punt
Keep yur eyes peeled for the MF amps though; the XA1, XA2 and XA200R's crop on eBay weekly :)
I dont much about the creek, there is a musical fidelity x-80 on flea bay at a good price, that might be worth a look.
roym90
39
Thanks again, I'll keep a look out for some MFs as the Creek still has a week or two to run, but its a buy now or best offer.
Or if I find enough good stuff about the Creek maybe just give it a go!
