bigboss said:Wait for Boxing Day sales if you can.
bigboss said:Personally, if I get the Oppo for £450 as gel suggested, I would go for that. Better build and features (also plays SACDs).
The_Lhc said:bigboss said:Personally, if I get the Oppo for £450 as gel suggested, I would go for that. Better build and features (also plays SACDs).
Better than what? The Panasonic? I just don't particularly like the looks of the Oppos really. Suppose you get used to it...
bigboss said:The_Lhc said:bigboss said:Personally, if I get the Oppo for £450 as gel suggested, I would go for that. Better build and features (also plays SACDs).
Are you interested in the looks of the player or their performance? 🙂
Panasonic is plastic with a metallic finish paint. Oppo is metal.
gel said:The Oppo is good! And has excellent customer service. I would definitely buy an Oppo again.
gel said:Your mate David would probably give you a discount.
The_Lhc said:gel said:The Oppo is good! And has excellent customer service. I would definitely buy an Oppo again.
So why did you get rid of the one you had? And what did you need the customer service for?
*smile*The_Lhc said:gel said:Your mate David would probably give you a discount.
I don't know what you're implying, you impertinent rapscalion!
gel said:The_Lhc said:gel said:The Oppo is good! And has excellent customer service. I would definitely buy an Oppo again.
Because I had two with my Pioneer and the Oppo was worth more, that's another reason to buy it they sell well. Firmware update discs can be sent to you by Oppo if you wish.
Not sure, I think they do.The_Lhc said:gel said:The_Lhc said:gel said:The Oppo is good! And has excellent customer service. I would definitely buy an Oppo again.
Do they update over t'internet?
gel said:Not sure, I think they do.The_Lhc said:gel said:The_Lhc said:gel said:The Oppo is good! And has excellent customer service. I would definitely buy an Oppo again.
The_Lhc said:No, I'm not particularly interested in second-hand, what are the loading times like on those?
The_Lhc said:Won't play DVDs? What's the point of that?
The_Lhc said:The main problem I'd have with that is that my current player is from 2009 as well and if that's starting to have issues with discs then I wouldn't have any confidence that another of the same age wouldn't have the same trouble sooner rather than later.
