nads said:matthewpiano said:The question is, how do I go about 'modernising' the source part of my system, bearing in mind that manageable navigation of a huge number of classical titles (in addition to all the other stuff) is of prime importance (and something that the existing Squeezbox 3 can occasionally hinder), do I:
TBH it will all come down to how you TAG the albums. If you do it well then I cant see an issue with the SB3 and certainly not with the Touch.
How many Clasical CDs do you have? and how/what are you using for taging now? when looking for some music how do you want to search for it?
I'm currently ripping using iTunes (ALAC with error correction switched on). Occasionally there are issues with incorrect or incomplete album info which aren't the Squeezebox's fault. I have been having issues with Squeezebox Server splitting a single disc into two seperate parts but I've just managed to sort that out by changing a couple of settings, so I'm not sure there is too much of an issue now, apart from the small display on the Squeezebox 3 that doesn't show much information at any one time, but the image/artwork display of the Touch would resolve this.
In terms of numbers just over half of my nearly 3,000 discs are classical and the number will only keep growing, although once I'm established with streaming I'm keen to start thinking about lossless (and better) downloads. What I will need to think about then is the best way to back everything up.
