Move over Logitech!!!
It does look sexy ! - but does it look practical ? It could do with some extra tactile buttons on the fascia I reckon. 🙂
Besides there being no coloured buttons on it, there isn't even a four way direction pad on it !
I'll wait. Sooner or later someone will make a universal remote that's so big you'll have to get up from your chair and walk to the corner where it's installed to use it.
Fahnsen:I'll wait. Sooner or later someone will make a universal remote that's so big you'll have to get up from your chair and walk to the corner where it's installed to use it.They already have - and they named it the 'ipad' !
On the opposite end of the price scale, I bought this a week ago:
http://www.amazon.co.uk/One-All-URC8305-Kameleon-Control/dp/B000KGG5DU/ref=sr_1_1?ie=UTF8&s=electronics&qid=1264935189&sr=8-1
It's absolutely brilliant. I tried one of the early incarnations of the Kameleon series and it was woefull. This has the macro feature that you find on the expensive Harmony remotes:e.g, one press of an allocated button to turn on TV, Sky box and AV amp together. Combined with a really easy set up. The 'learning' feature is a doddle, too. Any buttons that aren't recognised as standard, can be programmed in just by a couple of button presses and pointing the original remote at the Kameleon.
All this is great. Best of all, though: IT'S BLOODY 17 QUID!
Get one, before they push the price back up!
