Mordaunt-Short Aviano 1 vs Aviano 2
Was wondering if anyone has heard both of these. I can borrow a set of 1's to listen to but not 2's. So was thinking that if I like the 1's then hopefully the 2's are just more of a good thing. Mordaunt-Short is very hard to find here in the States so not alot of options.
Thanks!
Have been listening a lot to ther 1's and they do sound very good, especially for their size. The bass especially is noteworthy!
Anyone with a comaprison of 1 and 2?
i haven't heard either of these but i don't think that you should assume that the larger and pricier Aviano 2's will be as good or better for you .
If you are listening in a smallish room ,the bigger speakers extra bass
may be too much and swamp the rest of the music.
i dont no how much you are looking to spend but in rs the aviano 1s are £199.thay also have the mezzo 1s for £199. could be worth a look.
admin said:
Was wondering if anyone has heard both of these. I can borrow a set of 1's to listen to but not 2's. So was thinking that if I like the 1's then hopefully the 2's are just more of a good thing. Mordaunt-Short is very hard to find here in the States so not alot of options. Thanks!
The cheaper Mordaunt 902i is more appreciated than the Aviano 1. Had them both. I concur.
Gotta love a thread revival ! . . Its only been about 5 years
Are Mordaunt Short still producing speakers ? Anyway, the Aviano 6 was a good floorst, punch and confortable highs ... *clapping*
