Monitor Audio RX2 x QEF Q300
Hello experts, i need ur help!
Ive been looking for my first setup and im yet to decide wich speakers im getting...
Im going for a HRT music streamer II + Marantz PM6004 or 8004 + Pair of Bookshelfs.
After a really long time researching i found 2 bookshelf models: Monitor Audio RX2 x QEF Q300
First of all, i live in a small city and i will not be able to audition bookshelfs, so ill buy it blindly!
How u guys could compare both bookshelfs? Which one is more present on bass? I listen mainly rock so bass and mids are very important.
Thanks for help!
Frank Harvey
567
If you can afford RX2's, I would be choosing between those and the KEF R100. The R100's are better quality than the Q300's, as good as they are. I would taken any R model over any Q model.
Might i suggest another speaker for consideration. The B&W CM1. I didn't hear the Kefs but i found the RX2's quite bright, even harsh by comparison. I have the Marantz PM6004 amp and decided on the CM1s after a very careful and lengthy (3 hour) audition. They're extremely well built too. If it means anything the RX2s were the top of my list but after hearing them i discounted them quite quickly.
MUSICRAFT
Thanks for help!
Hi ricardovaz
Monitor Audio's Silver RX2's with incorporating their big 8" mid/bass drive potent help reproduce a potent bass with a clear, crisp and dynamic mid range presentation which should suit the genre of music that you mainly listen to :) Alternatively Dynaudio's DM 2/7 speakers are also worth a look.
http://www.dynaudio.com/int/home_loudspeaker_systems/dm/dm_27.php
Btw, what interconnect and speaker cables are you considering?
All the best
Rick @ Musicraft
+1
Amen to that..The R100's are AMAZING
ASK THE COMMUNITY
