gowiththeflow
David@FrankHarvey said:People think that lowering the box count reduces cabling, but it doesn't seem to, even in an active system....
.....The Dynaudios were based on £900 speakers, and retailed for £2300, and you then had to add your source. A good £500/600 amp would work fine with the passive versions.
The difference for me is the difficulty of having to run thick, heavy speaker cables around a room, on one side across a doorway and on the other side, across to the other side of a fireplace; versus a short mains lead from the back of the speaker, into a very close by and convenient wall socket. The speaker cable cannot be hidden under the carpet, or floor (solid) and is an eyesore. The mains cables would be much shorter largely hidden from view.
Then there are the other choices and compromises associated with speaker cable to be considered. Doing away with speaker cable has to be the greatest benefit.
As for the Dynaudio speakers, presumably you are referring to the original and now superceded Xeo 3 & 5 models? The current Xeo 4 & 6 retail at only £555 & £600 above the equivellent Exite models, the X14 & X34 respectively.
I would say that £555/600 is very good value for on-board DAC's and multiple power amps, specifically and optimally matched to the drivers.
It's an etirely different situation with the cost of the Focus XD speakers series. Dynaudio's pricing is adding between £2195 and £3545 to the cost of the equivellent passive Focus models. Then again, a suitable high quality integrated or pre/power to match the Focus series speakers, will set you back from £2500 to £6000 or more. That's before DAC's are factored in.
