Monitor Audio BX2
I've just been to pick up my Monitor Audio BX2 tonight to match it with my Yamaha 667 Receiver. I'd previously been using some Satellite Speakers from a Logitech Z5500 DTS system and the quality difference is amazing!
I was worried there wouldnt be too much of a difference and it seems to pair quite well with my Q Acoustics 2000c im also using ( i was going to periodically upgrade to the Q Acoustics 2000 but decided to go for a speaker system slightly higher)
Im not sure whether ill bother with Centre just yet but im going to get the BXFX in a few weeks off Santy
Also managed to get some QED Silvery Anniversary - 25m for about £30 which im over the moon with. Havent cut it to lengths yet and im still using the speaker cable which comes with the Logitech system I had so hoping that will push system evn higher?
If it's a question of either or. I'd seriously consider adding the BX centre ahead of the rears.
Having the front 3 speakers matched correctly is v. Important.
I agree....
Pistol Pete1:I agree....
+2
. Also, having the MA Bronze centre myself, it produces great detailed sound when watching 'normal' over the air broadcasts when you dont want the audio bouncing around the room. Definate priority IMO.
Nick
