Marantz MCR603 new firmware available
Hello everybody.
Last week I upgraded the firmware of my Marantz MCR603 to the latest release.
Since then I can't see the receiver from any other DLNA device as I used to (can't see it from my Galaxy Tab 10.1 tablet as before for example).
It can't see my DLNA NAS, as it used to.
Does anybody else experience this kind of issues since installing the new firmware?
Cheers!
XMB
After every software update on this unit I find you have to perform a full reset in order to guarantee all functions will work correctly. I tend to find AirPlay stops working after I have updated the firmware but a full rest always fixes the problem.
To fully reset (re-initialise):
1. Turn off the power using the ON/STANDBY button on the unit and unplug the mains power cable
2. Plug in the mains power cable WHILE pressing volume UP button and STOP button simultaneously
XMB
The following is the changelog for the firmware update:
13.09.2012
Main 02.12
Main Airplay E2.12
Internet radio stations registered in the FAVORITE will not be able to access after the Firmware Update.
Last.FM malfunction ("Not available in your country")
The default setting of Auto Standby was changed to "On".
The switch to Napster and the display of Napster were deleted.
