Marantz CD17
Zigwolf
Hi
I have a Marantz CD-17 C.D. Player bought in March 1999. It now sounds pretty awful - especially when compared to a cheap Blu Ray Player I also own
My question is should I go to the trouble of seeking a repair to this player (New Lazer ?) or simply buy a new machine ?
Thank You - Alan
Welcome
Are you sure the lazer is the problem with the sound? If lazer is damged or dirty it simply wont read the disc and skip.
You may be better off getting another 2nd hand player
Zigwolf said:
Hi
Thank You - Alan
Best to look at a replacement machine. New budget CDPs will probably work out cheaper than a repair, once you've factored in the parts, labour, carriage charges. Then, of course, there's no guarantee that something else (mechanism, transport itself) won't go wrong.
Look at newer Marantz, Arcam or Rotel.
Hi - Thank you for your replies - you both suggest a new CD Player. So:-
I am currently playing my CD's on a previously, barely used, Sony BDP-S760 Blu Ray Player.
Would a decent dedicated CD Player give better results?
If so, how much do I need to spend to get decent & enjoyable sound? And
Do any of you have a personal favourite CD player to recommend?
(Denon AVR-X2000 Surround Amp) (Castle Harlech Speakers - Yes, they are another question for the future)
Thanks again
Alan
Thanks again
Alan
There will be a difference between a dedicated CDP and a Blu-Ray player, but not as big as you might think. I know that my Panny Blu-ray CD playback is almost as good as my old Arcam CD73. The differences were pretty subtle.
I would be looking at minimum Arcam FMJ CD17, or Roksan Kandy CDP or Rega Apollo-R. But it'll depend on your budget.
