Make me a speaker short list!
Jonesiani
17
Hello everyone.
I'm going to begin demoing some speakers soon. I'd like some help at arriving at 5-6 models to demo with.
Budget is up to £800
I have Marantz CD6004 and PM6004,with Chord crimson plus interconnect, and a Copperline alpha mains cable for each of them.
Speakers will be in a living room, with carpet, standard living room size of 12x 14 feet.
The only speakers I've heard with ,y system have been the kef q500, and whilst great, I found them lacking in bass. I am, however, not a huge bass head, and I enjoy a detailed sound. I listen mainly to prog rock (porcupine tree, Opeth, MESHUGGAH, mars Volta) and anything up to limp bizkit and chill out music, and 80s pop.
I will consider both floorstanding and stand mounts.
What hifi say good things about the q300s and Tannoy floorstanders, what do you think?
I look forward to reading your ideas.
matthewpiano
494
330
19,270
I would suggest auditioning the excellent Dali Zensor 5 floorstanders. Very musical speakers, like most Dali designs. Also try some bigger Focal standmounters - the Chorus 806v are superb. Both Dali and Focal work well with Marantz.
Jonesiani
17
Thank you,
I should also point out that the speakers may have to be close to a wall, as space is premium.
matthewpiano
494
330
19,270
Then you might also wish to try the Dali Lektor 2s which are front ported and work very well close to a rear wall. The Zensor 1s are actually every bit as good, but they do prefer a little more space than the Lektors.
plastic penguin
Jonesiani said:
Thank you, I should also point out that the speakers may have to be close to a wall, as space is premium.
That won't be a problem for Focals, they are front ported. Also consider ProAc Tablettes, AE, and although rear ported, Ruark Sabre III (retail usually around £900-£1,000 mark, but because they are a little long in the tooth there may be a deal going) which are superb and perhaps the newer Epos marks.
toyota man
79
Not much help with your speaker problem I know but if you are into your prog rock you should listen to Big Elf Coheed & Cambra and Uriah Heep not much help I know good luck in your searching:rockout:
toyota man
79
gangus
9
I have the Marantz PM6003 and have been auditioning theCD6004 with:
MA BX2, MA RX1, MA RX2, B&W685, KEF Q300
My first choice is the MA RX1 which I will be purchasing soon.
The MA RX6's might also be worth a listen. I didn't audition them as they were out of my budget.
good luck
