Mains for Nad D3020
gasolin
BANNED
I use clearer audio power mains, but i have bought the Nad D3020 and it seems clearer audio is not making mains for the amp.
Any one know who makes this high perfoamce C5 (figure 8 with earth) power mains? (have wrote to cleare audio if they make such mains)
Ypu may be able to use this adaptor with your existing cable.
http://www.russandrews.com/product.asp?lookup=1&region=UK&currency=GBP&pf_id=1879&customer_id=PAA2316048114054IBKBJENMUSJOXMZE
Found a cheap adapter for about 6£,8€ hope it dosn't have a negative effect because it's not a goldplated 20€+ adapter
So long as the power rating of the cable is above that required by the amp, then it does not matter whether you spend £5 or £500, have plain Jane or posh connectors, there will be no difference in the sound. (A filter may help if you have particularly bad mains, but the cable will make no difference at all)
Hope this helps
Bill
