Mr Spock:Sorry Rick, I have changed my receiver from the Denon 1803 to the Onkyo TX-SR706 where the power cable can be changed. I have purchased a Chord power cable to replace the original one. I have installed extra power points. My plan is for the receiver, sub-woofer and the LCD TV to have their own power point. My blu-ray and dvd players will be sharing a power point and will be connected via a Tacima surge/conditioner. Should I connect the receiver and the sub-woofer directly to their power points using the specialized power cables or should I add a surge protector? If I decide to go the second way, do I lose any additional benefits through using the specialized mains cable? Thanks
School of thought could be that as the receiver and Sub make big demands on power ,and needs to draw amps unrestricted, that nothing should be in line to strangle the supply, adding an expensive power cord and then choking it with a surge protector to my mind would be doing just that.
Unplug your gear at the end of play if you are concerned about surges, you shouldn't be using your gear while there is lightning about anyway , also even if I had a surge protector I'd unplug in that circumstance.
Using a Tacima with CD and Blu ray is different and by all accounts gives the most benefit.
