- Aug 10, 2019
- 2,556
- 3
- 0
hello.... again. I brought these speakers new about 8 years ago from richer sounds when i found out i was going to have a kid i put my pride and joy in the loft wrapped in plastic so they didnt get TFTS (toddlers finger tweeter syndrome). 6 years later iv decided to get myself a marantz mcr603 for xmas
i connected my still new looking ms206 on the new amp but one of the speakers has a crackle on vocals especialy. Iv swapped the individual speaker from the left housing to the right to make sure its not cable related and its still there
you can feel the coil rubbing inside if you push/pull the cone but i have found that if i put a packer under one of the screws it fine no rubbing and perfect sound
1)any idea why this has happened
2)could it blow my amp if it rubs on the coil at a later date and shorts (think it has a protection circuit)
3) im my head these were super speakers think they had a rrp of £600 before MS went bump are they any good compared to B&W cm1's
4)will my repair last, i was told its called sagging and to rotate the speaker 180 in the housing if so is it a comon fault?
thanks again for any input
oh one last thing although it might need another post in my marantz i cant get web control to work i have the iphone app working but on my pc but when i type the ip address of the unit i just get an option to change the marantz name
