MA Apex speaker cable advice urgently needed please!
I have several questions that I really could do with some help on...
It's been suggested to me that I use QED original 79 strand to use with the A10's. Has anyone used this or has any other suggestions?
Also, I need to run a sub cable a distance of approx 12m (is this length ok?). Can anybody recommend where I can buy and what make I should consider?
Because there is very little space in my AV unit I need HDMI cables with right angled plugs, again can anybody recommend where I can buy and what make I should consider?
A lot of questions but if you guys could help it would really be appreciated as I take delivery on Friday
TIA, Dave
MUSICRAFT
Flyman:I have several questions that I really could do with some help on...
TIA, Dave
Hi Dave
Standard speaker cables between 79 strands or ones with several hundred strands of OFC will be more than good enough for Apex speakers. Fwiw i use these standard speaker cables with Apex speakers as well as PL100, PL200, PL300, PLC150 and PLC350 speakers.
12m is fine and a standard interconnect for the sub should do the job perfectly well. Having said this QED's Performance sub cable is also worth a look for the Apex AW-12.
Iam sorry but i can't think of HDMI cable with right angled plugs.
All the best
Rick @ Musicraft
MUSICRAFT:
Flyman:
TIA, Dave
Hi Dave
All the best
Rick @ Musicraft
Hi Rik ,
I've also been looking at the following all fitted with Airloc Banana plugs.
Chord Carnival Silver Screen
QED XT-C Cable
QED Silver Anniversary XT cable
Do you think its worth paying the extra for these cables and do you think I'd notice a difference in sound quality?
Many thanks once again
Dave
Gerrardasnails
295
MUSICRAFT:
TIA, Dave
Hi Dave
All the best
Rick @ Musicraft
So Rick, basic, cheap as chips speaker cable for £5k floorstanders but an upgraded brand name cable for a £750 subwoofer?!
aliEnRIK
92
My suggestion is to stay away from QED. It tends to be bright and hard sounding
Id recommend 4 or 6mm Van Damme UP LC-OFC for the speakers and 6mm for the sub
Flyman:Because there is very little space in my AV unit I need HDMI cables with right angled plugs, again can anybody recommend where I can buy and what make I should consider?
I recon this should do the trick
http://www.amazon.co.uk/Cable-Tex-SWIVEL-ADAPTER-90-270-DEGREE/dp/B003WUHKF8/ref=sr_1_1?ie=UTF8&qid=1296566606&sr=8-1
winyip:
Flyman:
Thanks winyip,
This looks like it may do the job, thanks for the info.
aliEnRIK:
Hi aliEnRIK,
Have you a preferred supplier for these cables?
Guys this might sound silly but do I need to put plugs on as I was told it isn't necessary?!
MUSICRAFT
Flyman:MUSICRAFT:
Flyman:
TIA, Dave
Hi Dave
All the best
Rick @ Musicraft
Hi Rik ,
QED XT-C Cable
Dave
Hi Dave
Your welcome.
I think you should save your money and consider using standard speaker cables. I feel if standard speaker cables are good enough for Monitor Audio's reference Platinum series of speakers then these cables will also easily take Apex speakers in their stride.
Btw, I'll also recommend say some basic heavy duty crimp type speaker plugs (which generally cost very little).
All the best
Rick @ Musicraft
Oh well I've done it now - Just bought 29m Van Damme 2x4.0mm UP LCOFC Hi-Fi Speaker Cable for the sats and 14m QED Performance Subwoofer Cable...ouch!
Thanks everyone here who posted and really appreciate the assistance.
michael hoy
793
279
19,270
Flyman:
Good choice Flyman.
MUSICRAFT
Gerrardasnails:MUSICRAFT:
Standard interconnects are perfectly capable of being used with sub woofers. However if within budget then QED's sub cables have been very consistent over years and also offered VFM. As i feel confident with QED's sub cables i am also happy to recommend them.
All the best
Rick @ Musicraft
michael hoy:Flyman:
Good choice Flyman.
Thanks Michael,
Going to go and collect the all kit on Friday afternoon so I'll be having all weekend to play!
Trouble is we've got friends for dinner sat night...Doh!
michael hoy:Flyman:
Good choice Flyman.
Hi Michael,
I notice on the Van Damme cable it say that its 'directional'. Does this mean that it has to be installed facing the same way on each speaker and if so is there a right & wrong direction?
Dave
michael hoy
793
279
19,270
Flyman:michael hoy:Flyman:
Good choice Flyman.
Hi Michael,
Dave
Yes the cable is classed as directional, the cable has a series of arrows on one side these arrows need to point in the direction from your amp to your speaker.
Some will say it does not matter, but if you follow this for all your speakers you can be happy that they are all wired the same.
