So I have the following burning issue:
My setup is the following:
1. Samsung Galaxy S20 with Apple Music capable of playing Hi-Res Lossless Audio and Dolby Atmos music
2. Apple Multiport USB-C - Digital AV Adaptor muf82zm/a that I used to connect the phone via a certified HDMI cable to the soundbar
3. JBL 9.1 Soundbar that has only HDMI in and optical in (and AirPlay2 and Chromecast)
So I connected the phone via adapter+HDMI cable to the soundbar, yet the sound does not seem to be right, compared to Chromecast directly to the soundbar.
My question is how can I transmit a Hi-Res Lossless 24bit/192 kHz and/or Dolby Atmos signal from my Samsung Galaxy S20 to my JBL9.1 soundbar.
I already ordered a USB-C to HDMI cable to make some extra tests and I'll update you with the results.
Also tried a similar setup with an iPad Pro 2nd gen, an Apple Lightning Digital AV Adapter with the same certified HDMI cable to the JBL 9.1 soundbar.
It does sound a lot better yet it does not want to play the Dolby Atmos content. (I choose to always play DolbyAtmos files in Ape Music settings and it skips over them)
Some help would be appreciated as I have already learned the importance of an external DAC yet putting one between the phone and soundbar would make no sense since the soundbar does not have an analogue input
*Edit 1: tried my luck with
a) Samsung Multiport Adapter EE-P3200BJEGWW, Type C/HDMI/USB + HDMI cable
b) Samsung DeX Cable EE-I3100FBEGWW (USB-C directly to HDMI)
with the same results
c) tried to fiddle into developer mode and sound settings
all without any success.
