the_lhc:maxflinn:Andrew Everard:
	maxflinn:so then .. lossless audio is compressed , to make it easier to fit it onto cds , so it takes up less space on a pc , usb stick etc , but it then can be uncompressed and played back with all the data there ??
You really haven't read this thread have you? No, the original audio recording can be compressed in two basic ways, in order to fit more of more of it onto a storage medium:
- You can use lossy compression, such as MP3, which throws away some of the data to reduce the file size. Think turning a word document into a plain text .txt file, losing all the niceties of formatting, font type/colour,hyperlinks and so on, in order to create a smaller file.
	- Or you can use lossless compression, which retains all the data, but creates a file that's larger than an MP3, but smaller than the original audio. To use the word analogy, it's like using WinZip or Stuffit or whatever to create an archive.
Frankly if you're thinking of using FLACs or ALACs or Apple Lossless, I personally don't see any reason not to just store WAV files, given how affordable storage is these days.
ta andrew , its a little clearer now i think ..
its confusing though , i thought that "lossless" just described a way of copying/storing files that was an exact copy of the original , and there was no compression involved when transferring/storing .
It can be, if it's uncompressed, however Lossless can be compressed and still be Lossless.
i didnt realise that music stored on a cd may be compressed , but still lossless  , a cd that you may buy in hmv etc , i thought they were uncompressed  Max, that isn't what Andrew said at all.
no , not saying he did .. just trying to figure out , if one goes into a shop and buys a few cds , can the data stored on them be  either compressed or uncompressed ?? we,ll say for example to enable getting more songs on an album ?? i thought up until this thread that the data was uncompressed ?
