Looking To Upgrade Amp - 2 x Speaker Outs Needed!
The_Lhc said:
Battery packs?
DIELECTRIC-BIAS SYSTEM
"All insulation slows down the signal on the conductor inside. When insulation is unbiased, it slows down parts of the signal differently, a big problem for very time-sensitive multi-octave audio. AudioQuest’s DBS creates a strong, stable electrostatic field which saturates and polarizes (organizes) the molecules of the insulation. This minimizes both energy storage in the insulation and the multiple nonlinear time-delays that occur. Sound appears from a surprisingly black background with unexpected detail and dynamic contrast. The DBS battery packs will last for years. A test button and LED allow for the occasional battery check."
http://www.audioquest.com/rocket-series-speaker-cables/rocket-88
FWIW, just get the best amp, regardless if it has two pairs of speaker high level outputs. You are disregarding a lot of amps that way that may well be better.
FWIW i have done just that. I have found an amp that i love with the connections i wanted.
Again if you see my previous post i have now got the amp i wanted and posted my findings and final result that's all ..... 😉
