I am looking to upgrade my amplifier to something in the £1000 to £1500 price range, but have a problem that i think a few people on here have come across before. I need two sets of binding posts for the speakers.
Having recently upgraded my speaker cable which i am absolutely happy and delighted with i do not want to change this, and they are factory terminated for bi-wire or bi-amp option at the amp end.
Although i am looking for an integrated at the moment, i want to leave my options open in the future for maybe a pre/power combo so don't want to re-terminate them either. Box count, room size etc at the moment means i definitely want an integrated at this stage though.
My system comprises of playing Lossless and HD tracks through a M2Tech Young DAC, Cyrus 7 Amp with PSXR and PMC DB1i Speakers.Cabling is all Audioquest, Columbia I/C and Rocket 88 Speaker Cable.
I feel that the weak link at the moment is the Amp side (being a few years old), and sometimes is a tad bass light with certain tracks.
Not wanting to go with Cyrus again i have come across the following which seem to fit roughly in the price range with the speaker output spec i am after.
Creek Destiny II
Arcam A38
Yamaha A-S2000
Marantz KI Pearl Lite
Looking at the prices of these, the value at the moment seems to be with the Marantz, especially when it's not far off £1000 cheaper than the Creek and the others, and i also love the sound having had many Marantz amps in the past.
With this difficulty of finding quality amps with the two sets of speaker outs obviously the normal suspects of Roksan, Primare, Naim, Sugden, MF etc can't be considered
So what i'm looking for is if anyone has any opinions on the amps i mentioned, or can come up with anymore to consider with the specs and quality i'm after?
Really want something that will be an improvement on the Cyrus kit i have and work well with the PMC's.
Thanks.
Creek Destiny II
Arcam A38
Yamaha A-S2000
Thanks.
