hi everyone, new to all this speakers and av reciever stuff not sure what direction to go in, i have £1,500 to spend on speakers and av reciever..have quite a large room, 7mts by 6mtrs .........any suggestions[*-)]
Have a look through the best buys section but id consider spending £1000 on the speakers and then £450 on the amp and get Yamaha RX-V667 or the Onkyo 608. In last months magazine i think it was, they tested various speakers and amps and it was agreed that the speakers are the ones to spend the money on
B&W 685 speakers would be a great purchase but would dip into your money for the amp
ok thanks for your reply, been looking at sony str da 3500, guy in shop recommended it, and 5.1 seperates,wharfdale 10.1,q acoustics 2000 series, b&w, mordaunt avianor 1....read all reviews just can't make my mind up, have no experience with speakers, head in the shed!!!!!
if you have the cash then id arrange some time with an AV shop and get them to Demo some of their equipment. Richersounds are ok, but their choice of speakers is very limited in store so id try and find a specialist dealer
Think the 3500ES only got 4 stars in the magazine so id probably demo a few of them before you buy off another persons advice....especially sales men as they tend to push specific stock to anyone with little experience.
For your budget id get a cheaper amp for say £500 Denon 2300 can be had for about that now if you shop around but isnt HDMI 1.4 or 3D ready but brilliant amp.
Speakers make a system more than an amp though, so you want to spend alot more on them than the amp.
I'd honestly ring a local dealer and get them to test a few for you one day and then you can part with your cash. I'd go for the Denon 2300 over the Sony 3500ES though, the 2400ES is probably a better option and then B&W 685 Speakers
I'd even consider not purchasing a Subwoofer to begin with and purchase that at later date and get higher grade set of 5 speakers. I have Q Acoustics 2000C and it just isnt going to blow you away for the price
Yes you could spend more on the speakers but you want to make sure you get the best out of them.I would try and find some £1000 plus speakers that had been discounted and increase the budget on the amp.What kind of speakers are you looking at sub/sat, traditional speakers, floorstanders this will help us narrow down a good selection.With that size room i would be looking at a good set of floostanders and the MA bronze range BR5 should be got for around £750 this would give you a good budget for your amp.Try an audition if you can and some of last years £1000 plus models will be knocked down by 20 to 50 %.
A google price check and i think for £707 you can get the MA BR2 5.1av speaker package and a Yamaha amp works well with this so the Yamaha rx-v2065 for £520 would be a good deal, but you can always check out the newer models if you want 3d try the Yamaha rx-v767. Also you may be able to get a deal when buying the two products together ie some free speaker cable, and the possibility of upgrading the front speakers.
sorry for slow response, been out, now getting back.........all your info is really helpful, what i want is 2 floor standers for front,centre speaker,and 2 rear speakers on stands,plus a sub, only thing is i have read so many reviews on so many different speakers i don't know which ones to go for, i know a lot of this is down to preference but would like to get it right first time, cheers
Thanks for all your help everyone I have decided on Monitor br5 av speaker system, only 1 thing left, is the amp. what is best for these speakers, much appreciated.
I would go with a Pioneer but a lot of people would recommend a Yamaha to match with monitor audio and i'm sure others will have a preference for onkyo or Denon so really you will need to make your own mind up which one you want to go with the BR5's. I think any one of the above amps would do a good job.
