I had silence from the guys at AVForums, so I thought I'd repost in the forums of the magazine that helps me decide on all the big AV investments..
Hi all,
I've put together (over the past year or so) the following setup. I was hoping for some opinions/critique on the build and if you think there are any weak points or anything else I should consider adding.
The build is as follows:
-TV: Samsung UE46ES8000
-AV receiver: Pioneer SC-LX56
-Speakers: Dali Zensor 5 (5.1)
-Physical media: Marantz UD7007
-Music: Cowon X7 fed to AV CD input (will migrate music to my NAS and use Marantz streaming)
-Headphones for late listening: Sennheiser HD650
-Others: Sky HD (crappy Amstrad built one), usual collection of gaming consoles, Dune Smart HD for ISO images.
I've maxed out the HDMI PORTS on the back of AV reciever now though so no thruther exansion unless I chain through one of the other units with an HDMI in if I add anything in the future. (XBOX ONE or UD7007 I guess)
This is already built and setup with the exception of the Marantz which is due to arrive Tuesday.
Is there anything you think is over or under spec or do you think components are generally well matched?
It's too late to change anything significant really, but I'd appreciate any opinions.
Many thanks,
Dan.
Hi all,
Many thanks,
Dan.
