- Mar 10, 2015
- 4
- 0
- 0
CnoEvil said:nissen1502 said:A little update.
I've decided not to buy a stereo amplifier because it seems like marketing ******** and placebo. I am borrowing my friends Hegel H200 and it sounds almost exactly the same as my Denon AVR-X500. It doesn't even have significant volume difference. With the Hegel costing 10x more I expected to actually hear a difference without sitting for hours barely hearing some stuff that I'm not sure is different or not compared to my Denon.
So after reading what might be wrong, I've found multiple blind tests which all prove that it makes no significant difference, so I've decided to go for a surround receiver with good room correction and probably upgrade to 5.1 sometime, but as for now, only stereo. Could you guys recommend a good room correction? I'm not interested in hearing "It sounds better" because in my experience, it doesn't. Speakers sound different. As for DACs, I don't know if they sound different as I haven't got anything to compare my Schiit Modi too, or the inbuilt DAC in my Denon. But so far they all sound pretty much the same. The only reason I would have a Hegel H200 over a Denon AVR-X500 is the bragging rights. And it looks nice.
Edit: And iQ speakers. I'm stupid for not checking this, but it seems your company sell Abrahamsen gear, so yeah, marketing. This is a really sad moment for me, because I actually really love music and care a lot about how it sounds. I guess I'll just stick to buying good speakers.
IME. An amp of the quality of the Hegel should be making a pronounced improvement. If it isn't (and you should trust what you are hearing), there is something else going on.
- That could be the speakers....are they Blu-Taked to quality filled stands / correctly positioned and stable / spiked into a solid floor (not a suspended wooden one)?
- Is there a quality source with lossless resolution?
- Are you using decent, no-nonsense copper cables, with the amp plugged directly into the wall?
- It could be the room....can you describe it and how the speakers are positioned.
- It is possible that you need speakers of the quality of the amp, to really hear the improvement you are striving for.
1. I got my B&W 685 S2's on some Dali Connect stands. The guy in the shop said they work perfectly with my speakers and I've never noticed a problem with them, so it shouldn't make a difference.
2. I'm running FLAC files and spotify. The FLAC files sounded a bit more open, but thats about it. I got a Schiit Modi connected to my PC with USB and then connected to the HEGEL with good RCA cables. I would probably hear a difference with a better DAC (If I even believe that DAC's make a difference, which I don't) but an amplifier that costs over 20000NOK should be able to make a difference without the DAC being super good.
3. Cables are not a special brand, but it's definitely not a bad one. It's 99.9999% oxygen free copper AWG 12.
4. I have a angled roof, and my room is a rectangular shape. About 3 meters in depth and 5 in length. My speakers are positioned about 30 cm from the back wall, and are equally distanced from each other. They are slightly angled towards the listening position. All my walls and my floor is wood.
5. Honestly, if you need speakers worth more than 5500NOK to even notice a difference between a 2000NOK 5.1 channel receiver and a 20000NOK stereo amplifier, then it's definitely just BS in my opinion.
