Look, its a CDT
El Hefe
259
11
18,895
Just got the new CDT hooked up. Lets see how it fairs against XRayV3. Review soon. In the mean time, I have a few questions:
1. Is XLR the same as AES? I am connecting the CDT to M1 DAC using one side of VDH The Second cable.
2. What is the advantage of AES over coaxial and optical cable?
3. Now that I have CDT connected to M1 DAC using AES and from M1 to M6i amp using XLR, does this mean the set up is fully balanced?
First impression of the unit is impressive.
El Hefe said:
Just got the new CDT hooked up. Lets see how it fairs against XRayV3. Review soon. In the mean time, I have a few questions: 1. Is XLR the same as AES? I am connecting the CDT to M1 DAC using one side of VDH The Second cable. 2. What is the advantage of AES over coaxial and optical cable? 3. Now that I have CDT connected to M1 DAC using AES and from M1 to M6i amp using XLR, does this mean the set up is fully balanced? First impression of the unit is impressive.
Answer to question 1 is No, AES is an audio format whereas XLR is a type of connection. (see below. Answer to question 2 is probably None. Answer to Question 3 is Yes "AES/EBU (Audio Engineering Society/European Broadcasting Union) is the name of a digital audio transfer standard. The AES and EBU developed the specifications for the standard. The AES/EBU digital interface is usually implemented using 3-pin XLR connectors, the same type connector used in a professional microphone. One cable carries both left- and right-channel audio data to the receiving device. AES/EBU is an alternative to the S/PDIF standard."
Congrats by the way, I'm sure it all sounds rather good!!!
Hi there, have you had the time for further listening session? How is the overall impression? I am going to replace my old Quad 66 next month to accompany my MF M6i. My plan is purchasing the MF M6CD. I see that you have M6i as well. So what is your opinion? Do you think M1CDT + M1DAC is suitable and in the same class with M6i or I should go directly to MF M6CD? Thanks a lot mate.
Save yourself £1000-ish and get the M1CDT/M1DAC. I haven't listened side by side but from memory, I really can't see the M6CD being worth the extra £1000+ or any other similarily priced CD player for that matter.
El Hefe
259
11
18,895
Here you go. The first 36 hrs review
Call me old fashion (although I am young hehehe), CD player is still an essential part of a good hifi system. For any new CDs purchased will still be enjoyed on a CD player. I usually spent a good 2 to 3 weeks on a new CD on the CD player before ripping it onto the NAS and iPhone. Listening to digital files is good for the convenience it offers to choose tracks, but it offers less musical involvement compared to CD. I think CD, which has a physical form of a disc gives me a psychological approach that there is a mechanism that is working to provide me the sensational feeling towards music. Digital files most of the time feels like its virtual. Its like someone who only chat on the internet but never goes out to socialise with real people. Not sure whether it make sense. In lay mens term, I feel CD feels real.
Now back to CDT. The main reason I want to test this unit is because I am intrigued by the 'balanced' set up. (Note: I have not purchased this unit. Its on loan for demo).
Now about the balance, a few months back when I purchased my M6i amp, I posed a question on XLR connection in this forum where I connect my M1 DAC to the M6i using XLR. However, I was feeding the M1 DAC with a signal via coaxial from XRayV3. So, the conclusion I got from this was that my set up was still not truly balanced. Some say XLR connection is only needed for long runs of cable and cheap units are not truly balanced eventhough there is an XLR connection offered on the unit etc. But I am still intrigued by the question whether a fully balanced unit is superior than the common RCA connection.
So, I was thinking whether to go for an M3 or M6 CDP. However, M3 does not offer XLR digital connection and M6 will make my M1 DAC redundant. Hence, when the CDT came into the market last month, I feel like testing and compare it with XRayV3.
Built
Being in the M1 series, its definitely very lightweight. It still has the sexy black look similar to my other M series kit. Size is similar to CLiC and M1 DAC which it then compliment each other. It has a standby button which I like as I dont really like leaving the CDP to be on all the time.The button lay out on the front fascia is well laid oout and very intuitive. The display is of a bright greyish green. It is a bit too bright at night and it could have been better if the design came with a dimmer like the XrayV3. I am leaving the plastic cover on the display as I may decide not to buy the unit.
The remote feels cheap though, similar to CLiC. The difference between an M1 and M3 or M6 series are significant and it can be seen on the remote. Luckily enough my M6i remote can also control this unit, so I repacked the CDT remote into the bubble wrap.
The AES, coaxial and optical sockets are well laid out and firmly fitted. There is also 2 triggers where you can conncet any additonal device for power that can be run on 12V I think (have to recheck)
Loading mechanism
The CDT has a slot in mechanism which takes you away from the traditional tray loading. So no worries on mechanical failure there. However, I was listening to 10 different CDs last night and today and twice I encountered that the unit rejected the CD after loading. It ejects the CD automatically but no issues on the second attempt.
The loading however is very quiet and it will read the TOC of the CD as fast as 2 seconds.
CD format
It offers CD Text and can play CDR and CDRW. One bonus point over the XrayV3.
Hook up
I connected the CDT to M1 DAC using one side of VDH The Second XLR cable and from the M1 DAC to M6i amp, I used Siltech Classic XLR cable.
For the XrayV3, it is connected as follows:
1. Via coaxial into M1 DAC using Cambridge Audio digital cable and via Siltech XLR above into M6i
2. Via X-10D V3 using QED Signature IC into the the X-10D V3 and also into the M6i amp
The session
The test tracks:
1. Andrea Bocelli - Time to Say Goodbye
2. Janet Seidl - Till I Have You
3. My Hero - Foo Fighters
Volume was set at my normal listening level - 9 o'clock on the dial.
The unit is brand new, so I guess it needs burning in first. So I wasnt expecting anything major improvement. But lo and behold, the instant I put on Andrea, the room was fill with music. There was this liveliness injected that I though I was listening to a concert version of the track. I immediately change the CD into my XRay V3 just to make sure my mind was not playing a trick on me. I first tested via X10D.
And yes, it did not. There is a big different in the high notes. The CDT gave a brighter presentation of Andrea's vocal and the accompanied musical instrument in which it can be a little overwhelming. I guess the this is because the X10D does inject warmness to the music. But it was still much livelier than going via X10D. And the loudness of course is lesser than the XLR connection.
I then switched the XRay V3 to the coaxial via M1 DAC. Here is when the difference is not that transparent. I kept repeating the track and switching between CDT and XRayV3. Although the liveliness, the CDT wins hands on, but the clarity and detail, cant hear much different.
Same goes for the low end notes. On the track My Hero, the bass drum on both XRayV3 and CDT, provide justice to the ProAc. Bass was full, taut and very controlled.
Putting on Janet Seidl (a HDCD), provides the same presentation between both. I could start comparing them with HDCD decoding via my X-DAC, but it was 1 am, so NO.
I went to bed by putting on the Andrea Bocelli CD on shuffle repeat. I concluded that digitally, there is not much different between a coaxial and XLR connection. But somehow, the CDT added the liveliness.
Same story the next day? Nope. A big nope. After running in for about 12 hours, the liveliness of the CDT is more uplifitng and the high end notes were less harsh. I repeatted the above tests and found:
1. The CDT provides a much more open presentation of the music, with maintaining the similar level of detail and clarity from XRayV3
2. The low end notes on both units are very controlled and defined. It made the ProAc seems larger than its size.
3. The 'analogue' connection via X10DV3, although sounds very warm, now seems lacking in liveliness. Warm is important to me but now it sounds rather flat. Ooohhh is the X10D V3 going to be on sale soon? Heheheh.
Conclusion
Hhhmmmmm a tough one. Do I replace the less than a year old XRayV3 with the CDT? Is it really an upgrade? Or I am just going parallel and just want to really believe that XLR/AES digital connection is superior than coaxial and optical, especially that this set up will define that my system is truly balanced? Or do I really want to buy in to the believe that separate transport and DAC provides a better set up?
Too soon to answer hhehehe. Give me a few more weeks with this unit.
El Hefe
259
11
18,895
Thanks Alears for the explanation. There is one more clarifcation that arise from your explanation:
On the M6i amp, M1 DAC and M6 CD, the terminals are labelled as XLR Balanced output (on DAC and CD) and XLR Balanced input on the amp. Where else on the CDT, it says AES/EBU balanced digital output.
However, all of them use the same XLR cable right? What I can understand from your explanation and applying it to the above, the XLR balanced output and input are then analogue and AES is digital. Is this correct?
So how does the the same XLR cable carries an analogue signal on the amp and CD and the same cable can carry digital signal from CDT?
Maybe I should have studied Electronic Engineering rather than Aeronautics. Hehehe.
El Hefe
259
11
18,895
Weha,
I tend to agree with Darren. Although I have not heard M6 CD on my set up. The one advantage I could see the M6 CDP over the M1/CDT combo is that it cuts out one balanced connection (CDT to M1). You can connect the M6 CDP directly balanced to the M6i amp. The upsampling also is already been done in the M6 CDP.
El Hefe
259
11
18,895
No review is complete without a picture.
El Hefe said:
Thanks Alears for the explanation. There is one more clarifcation that arise from your explanation: On the M6i amp, M1 DAC and M6 CD, the terminals are labelled as XLR Balanced output (on DAC and CD) and XLR Balanced input on the amp. Where else on the CDT, it says AES/EBU balanced digital output. However, all of them use the same XLR cable right? What I can understand from your explanation and applying it to the above, the XLR balanced output and input are then analogue and AES is digital. Is this correct? So how does the the same XLR cable carries an analogue signal on the amp and CD and the same cable can carry digital signal from CDT? Maybe I should have studied Electronic Engineering rather than Aeronautics. Hehehe.
From my limited knowledge the interconnect is purely a piece of wire with XLR type connectors at each end. That piece of wire can carry either a digital or an analogue signal. You normally only see these type of connections between a CD transport and an accompanying DAC. This then carries an AES/EBU signal to the DAC. Once the DAC has converted this to an analogue signal then it really doesn't matter how that signal is transferred to the amplifier. You could just as easily connect the DAC to the amp with a normal phono cable.
