Logitech Squeezebox touch remote issues.
nads
1,116
443
19,570
If this is not the right section please move.
if you are having issues with the remote control not working. There is a very easy fix. Replace the power supply.
there was talk about the sensor failing and people were getting there soldering kit out but then someone tried a different PSU and the remote now worked. Seems some of the parts in the PSU were failing and causing interference.
I have just tried my SB3 PSU and now the remote works. Any 5v PSU will work but if you want to use the USB make sure the PSU is the same as the original or has more Amps.
