Lg 65 c1 your tv setup doesn’t support 4K uhd at 120hz help
Dandare74
19
Hi I just purchased a lg65c1 and am running a Xbox series x through a denon 2700 receiver but on Xbox setup screen it says your tv setup doesn’t support 4K at 120hz. Can any one please tell me why I am getting this message because I can’t figure it out.
Tinman1952
For the lowest input lag and better game response you should be connecting your Xbox direct to the TV and using eARC out to your AVR. You will certainly get 4K/120 that way.
Dandare74
19
Yes hdmi are ok and don’t get the message when I do it directly from tv to Xbox but am new to this and cant figure out how I get 5.1 sound out of denon it just says stereo I am unsure what goes where.
Tinman1952
The eARC connection will support 5.1 channel sound but if your C1 is like my B9 then there is a software problem with the TV where it assumes PCM output is stereo. I get this with the PS5 and have to set the sound output to DOLBY on the games console. Try this and see what happens....🤞
Reactions: Friesiansam
