- Aug 10, 2019
- 2,556
- 5
- 0
Current tv is the Samsung LE40A656, and I'm looking to move to a 47" or 50" screen while maintaining similar (or better) image quality. Budget is about 900 pounds. I've considered the following:
LG 50PK790 - Good reviews, but I am concerned about reports of short-term image retention (plus Richer Sounds fellow mentioned there is a major issue with Sky box recorder retaining the symbols or some such thing in the lower left hand corner permanently...so he pushed me away from plasmas all together)
UPDATE: Purchased the LG and so far am happy with it. Does anyone recommend ISF calibration on this particular TV?
