LG 32LH3000 or Toshiba RV635DB?
I'm buying a second TV but am still looking for a decent 1080p set as I want to be able to plug my PS3 into it, though I'm trying to keep the price to a minimum.
I think the solution may be an LG 32LH3000 for about £350? Seems to have everything my Panasonic does except the 100hz. The only 32 inch rival under £400 that has stood out is the Toshiba RV635DB, but this has a slower refresh rate.
Is the LG the better option? Or does anyone have any suggestions on any other options?
Thanks a lot!
Rich
I've been bragging the new lg's but I notice from the models 37 inch upwards, there is some screen uneneveness. on the 32 im not sp sure.the sides of the screen appear much darker than the centre .and viewing angle is not so good either.
Thanks for the advice -
That isn't good regarding the viewing angle on the LG because the way our bedroom is it won't be viewed straight on.
The Samsung looks like it may be a better bet for not too much more.
Any opinions on the Toshiba?
