Hello!
Just a really quick question please. I have just purchased a Leak 70, but as you probably know it uses an older speaker plug system. However, I will just make my own plugs up. My question though is which hole is positive and which ground? I know it doesn't matter as long as both speakers are wired the same... but I have OCD.
I THINK the larger 4mm holes marked with what look like a fork are ground? And the smaller 3mm holes are positive. Is that correct? Thank you so much in advance!
