I don't know how they fit your budget, but I like Paradigm Seismic 110 and Velodyne SPL800 Ultra.shkumar4963 said:Welcome Josh. I have had these speakers for close to a year now. One speaker developed a minor crack in it but KEF replaced that driver with no questions asked. So I am good. Yes, they are incredible speakers. I am running them with Parasound Amp. (A/B 100 W). But in some songs with a lot of low frequencies (less than 55 Hz or so), it shows that something is missing. So I am trying to get a sub for it. I have tried a low end and a medium end ($899) Sunfire sub but that just resulted in non-transparent muddy sound. Seems like lack of low frequencies gives it an extra sense of transparency and clarity. Any suggestions?
Also they seem to get muddled in any songs that has a large band like Rock Music. The transparency and clarity that they are famous for just are not there. So I feel that they are best for jazz music and vocals. What do you think? Do you see the same behavior with complex music with a lot of intruments.
shkumar4963 said:It seems that in my current setup they are most transparent with Jazz music and any other music that has a limited number o (upto 5) instuments. Like "The Best of Eva Cassidy". For rock music they are not that transparent. I am not trying to fix this proble. I am happy with what thye have. Just wanted to see if others see the same issue. I may try a different amp sometime to see if that may improve the situation somewhat.
For music with deep low end, I am trying to incorporate a sub. So far my efforts have not improved the situation any. I do get low frequencies but at the cost of clarity. Wanted to know if others experience the same thing.
I will also try the sub suggestions that others have made.
Thanks. Keep your suggestions and experiences coming.
shkumar4963 said:What do you mean?
shkumar4963 said:So here is the plan for me. First try a sub and see if that provide the clarity and transparency at the low end.
If that does not work. Return it and try better pre amps to see if they help. If that does not work just sit back and enjoy what LS50 produce and there is plenty here to enjoy.
On a side note, I would like tiger if others experience the same lack of clarity at low octaves.
My long-term reference small speaker, the KEF LS50, presents a fuller, sweeter and softer sound balance; the SB-C700 is "faster" and clearer. Bass definition is firmer, treble is more distinct, there's more sparkle. The LS50 shrinks the music's dynamic contrasts; it's a less lively-sounding speaker. I still love the LS50 for its romantic glow, but the SB-C700 wins for sheer transparency and impact. Rosanne Cash's vocal and guitar on her "10 Song Demo" CD sounded a touch more naturally sweet over the LS50, but the SB-C700 wasn't far off the mark.
... lack of detail resolution and dynamic punch; lean tonal balance; cluttered and compressed soundstaging; poor rhythmic drive
Vladimir said:I think what WHF is saying is that at that high price point there are speaker who brutally annihilate the Technics (ATCs were mentioned).
Personally, I'd start with feeding a full fat digital signal into your system, from a CD player or some such source, using music you know well. Assess each link in the chain with an uncompressed signal, otherwise you could be wasting your time, or spending more time trying to assess than you need to.shkumar4963 said:On a serious note, I am thinking of starting with a clean slate to evaluate each component in my audio chain and start upgrading. I now have REW sound measurement system so that may be able to help a little. This may identify the problem better than me describing that the bass is muddy whatever that means.
so let's get started. My purpose will not be to merely identify what could be improved because everything can be improved but to identify the biggest bang for the buck component in sound improvement. So help me guys here if you can.
What tests can I do to identify the stage that needs to improve first. I will do the test and let you know what I found.
1. Source: Spotify MP3 320 Kbps digitally PCM fed to AVR Yamaha. or CD player fed digitally to AVR
2. How to test if AVR is working ok? I am using its DAC. And it is set with all DSP and treble and bass disabled.
3. How to test if Parasound 750 HCA is not a problem?
4. Interconnections: Monoprice premium cables
5. How to test IF LS50 are working ok?
6. How to test is subwoofer SVS SB-12 NSD is not the problem?
7. How to test if room modes are it playing havoc? Would room conditioning be the first thing to spend on? How to test for that?
Let me know your thoughts on how to test one stage or all stages. Whatever you can share will be greatly appreciated.
May be there is a link someone can share that has all ththese tests described. Sort of audio diagnostic checklist.
