Hey all,
I just installed the KEF 3005SE-W (799 at SuperFi!) with the Denon AVR-1910. After some tweaks (the Denon is an amazing piece of kit, but not the most straightforward setup..) the KEFs are effectively producing that effortless sound that I heard in the store. To be sure that I am getting the absolute most out of the combination, I had a couple of notes/questions:
1. The Audyssey routine was a mixed bag. I did it with 4 locations around the room, but it fails to detect the subwoofer no matter what I do. The good news is that it measured the distances accurately and I've adjusted the individual speaker channels so that I don't have to drive the Denon as hard (-10db initially!); I also noticed when I turned off all of the EQ settings in the EQ Customize section, the sound opened up measurably. Of course, now the red light is off and I won't get MultEQ or Dynamic EQ/Dynamic Volume. Speaker settings as follows:
Front L/R: +5.5db
Rear L/R: +3.5db
Sub: +1.5db
Speaker sizes set to small, speaker crossover frequency at 100hz, sub set as LFE at 120hz. Treble at +4, bass at +3 (not sure they are having an effect though...)
Q: Is there anything else I should consider looking at? Are the channel settings on target? Are there customised EQ settings to consider?
2. Is it recommended to use the bass boost (+6 or +12) on the sub at all? Or should I leave it to the receiver to drive? I ask because I occasionally miss some of the mid-bass impact (appreciating the fact that I am using satellites..)
3. For MP3 music playback (256k compression, streaming from Mac to PS3) are there recommended settings for Denon's 2.1 stereo mode? The bass feels a bit underwhelming in that setup but is normal on Dolby Pro II cinema/music..
4. Currently using QED Silver Anniversary XT cabling throughout (impressive). On the HDMI front, I am using ThatCable HDMIs (one each for PS3 and Sky box going into Denon, and then one coming out of Denon into the TV.) Will the Chord HDMI Supershield (from Denon to TV) be an improvement? Or do they all need to be Chords for there to be an improvement?
5. Any other settings to be aware of for the Denon + KEF combination?
Lots of questions, so I appreciate any thoughts/suggestions. Many thanks!
Mike
Front L/R: +5.5db
Rear L/R: +3.5db
Sub: +1.5db
Mike
