Keep Existing Stand mount or change to Floorstanders
ghudson
I have a Linn Classik with Quad 11l stand mount speakers on Optimum speaker stands. We have changed the look of the living room (6m * 4m) and we no longer want glass/steel speaker stands.
I have seen and like the Russ Andrews wooden speaker stands which cost ~330GBP.
My question is, should I get these speaker stands or perhaps change my speakers to floorstanders. My budget would be no more than 500GBP for the floorstanders.
Or, are there any other suppliers of wooden speaker stands?
MattSPL
19
If your happy with the sound then you should probably keep the speakers and find some nice wooden stands.
Or you could trade in your speakers for the floorstanding version if you like the sound of them but they will more than likely produce more bass in your room which may or may not suit.
ASK THE COMMUNITY
