Here you go https://eisa.eu/awards/reavon-ubr-x200/I am not sure where that particular award comes from? I don’t think WHF or Home Cinema Choice has reviewed it yet. Which other AV mags would give it such an award?
Nope, you set the output to video for HDMI 1 and audio for HDMI 2, and then you connect the video direct to your TV and the audio to your AV receiver.Is it just me or does this 100 player need a 4K amp? And it’s not compatible with 1080p amp? My CA player has 3 HDMIs on the back of it this player only has 2! I think you need an up to date amp for it!![]()
Tried that Bill, Spatial have confirmed it’s not going to do it with the old amps.Nope, you set the output to video for HDMI 1 and audio for HDMI 2, and then you connect the video direct to your TV and the audio to your AV receiver.
Bill
You said you returned your PS5 to BT for a full refund on Monday?When I hooked up the PS5 I set it to pcm and TV audio on my amp now I can’t get it back to Blu-ray BD and playing Master Audio - any ideas where I have gone wrong? Thanks
I believe Spatial are wrong in what they say.Tried that Bill, Spatial have confirmed it’s not going to do it with the old amps.
Already posted
correctI believe Spatial are wrong in what they say.
Looking at the specs, there's no reason why it can't work with older amps.
REAVON UBR-X100 - 4K Ultra HD Dolby Vision HDR10 Blu-ray Player
The Reavon UBR-X100 Blu-ray player is compatible with the Dolby Vision format which provides HDR image technology, SDR/HDR conversion mode, dual HDMI outputwww.reavon.com
HDMI 1 to TV and HDMI 2 to amp.
I did.You said you returned your PS5 to BT for a full refund on Monday?
States you can’t in the manual too.I believe Spatial are wrong in what they say.
Ok think I I misunderstood, you mean you changed some settings on your tv/amp to use the PS5 and now can’t change them back for the Blu ray player?I did.
Does he? I am confusedOk think I I misunderstood, you mean you changed some settings on your tv/amp to use the PS5 and now can’t change them back for the Blu ray player?
I don’t know hence the question.Does he? I am confused
I did and still don't know why you would want to book up a PS5 to a universal disc player, but that's just me.... Not my area of knowledgeI don’t know hence the question.
Read post #23
That’s what I first thought was going on but I read the manual and it states the player needs a 4K amp.Ok think I I misunderstood, you mean you changed some settings on your tv/amp to use the PS5 and now can’t change them back for the Blu ray player?
I haven’t I have got a refund for the PS5 a few days ago. The PS5 also only was compatible with 4K amps too, which in lies the problem!I did and still don't know why you would want to book up a PS5 to a universal disc player, but that's just me....
No he hooked up PS5 to his amp and TV and changed some settings to get it to work. That has since been returned.I did and still don't know why you would want to book up a PS5 to a universal disc player, but that's just me....
That‘s correct. I put the amp on TV sound to get sound from the PS5 via the amp. I can also get sound for the 100 player via TV sound settings on the amp remote. Both players are only compatible with 4K amps to get the BD settings on the amp remote and soundtracks such as DTS MA and Dolby True HD. These sound tracks won’t work on my amp with the PS5 or 100 player.No he hooked up PS5 to his amp and TV and changed some settings to get it to work. That has since been returned.
Now he is having trouble getting the blu ray player to work with amp and tv settings etc.
The player itself is really good, they just need to put on the spec it works with 4K amps only then there isn’t a issue.Hence I’m holding back doing Reavon until all the initial mess is over - 6 months down the line, all those who ordered wrongly or took a punt, made the wrong choice and returned will have been over and done with.
I don't think they are likely to sell many if they have to be used with a 4k amp, don't see it some how.That‘s correct. I put the amp on TV sound to get sound from the PS5 via the amp. I can also get sound for the 100 player via TV sound settings on the amp remote. Both players are only compatible with 4K amps to get the BD settings on the amp remote and soundtracks such as DTS MA and Dolby True HD. These sound tracks won’t work on my amp with the PS5 or 100 player.
Its working perfectly on my CA 4K Blu-ray player with my amp, I get DTS Master Audio etc through the BD settings on the amp remote.
Had a look at the manual myself and agree with BB. it should work.
