Al ears
BigH said:Al ears said:BigH said:Al ears said:BigH said:keeper of the quays said:My denon sounds fine with my metal platter..my mates dl103 sounds good on his metal platter linn too...i use a suede slip mat.
I think its to do with magnetic force will pull the cartridge towards the platter. Denon warn against using them with metal platters. The Linn platter is zinc/al alloy I believe, so not magnetic.
I cannot think of anyone these days that uses a steel platter and that's about the only thing that could be magnetic.
I thought Nottingham used steel? Pro-ject? And a lot of older TTs.
I believe most are aluminium or alloy. Nottingham might but I actually think they are alloy, how many turntables do they sell these days anyway, I wonder. ;-)
Also I cannot think of any older turntables that used iron or steel platters.
Really. I read on Pro-ject site it was steel, maybe not 100%, some older TTs had stainless steel, like Roksan? Some platters are heavy they would not use AL if they wanted the weight. Anyway I have read of problems with Pro-jest and Denon MC cartridges, tracking force if nothing else.
I'd like to see where it states the cheaper Project platters are steel. The Elemental et al use particle board. The bearing support is, however, steel.
Current Roksan and all models I recall have aluminium and alloy platters.
