Is it worth buying QED XT cabling for my system
Hi ive got a fairly low budget system which consists of the following,
onkyo 605 amp , kef iq7se front , kef q95c center , kef q35.2 side surrounds , q15.2 rear surrounds and subwoofer. would i hear a difference by using qed silver xt cables and airlocs. intialy for the front in biwire format .ive come to a point where i cant afford to spend a lot of money for major upgrades but would like to make tweaks with my exsisting system to make it sound the best that it can.
thanks for your help
sardean:Hi ive got a fairly low budget system which consists of the following,
If you are using basic cable, it's certainly worth trying. I would go on ebay though for some second hand Chord Rumour or Chord Odyssey. Don't worry about the Airlocs - they WILL NOT add anything to the sound.
