Is it the Cables or isit the plugs?
Benedict_Arnold
661
Was pondering this the other day.
You can wire your speakers up to some amps, not all, by just srewing them down under or through the binding posts.
Or you can fit banana plugs from a myriad of sources.
These can be crimped, grubscrewed or soldered.
So.
You spend hundreds on upmarket speaker cables.
Set aside whether "brand X" at a gazillion quid a centimetre is any better or worse than "brand Y" at a gazillion and one quid a centimetre.
Set aside whether you use el-cheapo grubscrew banana plugs from some shyster on "a popular we auction site" or whether you use hermetically sealed 6-N pure unobtainium solid-phase welded, heat treated in unicorn pee, items at a brazillion a plug.
What's the influence of the plugs and how they're attached?
What's the point of spending all that money on cables (and / or plugs) when you're basically relying on a friction metal-to-metal connection at either end anyway?
And then your wife gets out her Kylie CD (or worse)...
Okay, let the debate begin.
camcroft
938
575
19,770
CnoEvil said:
Do you believe cables are likely to make difference in the first place?
I believe they do but there is so much negativity about the subject that i just use two pieces of string instead and they sound great ;)
CnoEvil
556
14
I'm a frayed knot! :oops:
MajorFubar
690
8
It's a fair question. I use banana plugs: gold plated type with the cable clamped by a knurled screw on top. Mainly I use banana plugs so that I can unplug the speakers easily and move them for hoovering. I really don't think they can improve the sound. If anything at all, they compromise it by adding another link in the chain.
Benedict_Arnold
661
Up to a point.
I wouldn't use DIY-store "flat twin and earth" or doorbell wire, but I probably wouldn't pay stupid money, either. Where stupid begins, I'm not so sure. I guess spending 500 quid on cables for a 100 quid pair of chinese knock-off speakers might be a good example, though.
I do believe a decent cross-sectional area, good copper and good insulation and shielding play their parts. In my job we use subsea umbilicals, up to about 50 km long, to transmit control signals to and from subsea oil wells back to the controlling oil platform control rooms, and if the cable isn't up to it you just don't get a signal at the far end.
CnoEvil
556
14
Benedict_Arnold said:
Up to a point.
IMO. The quality of the connection is more important than the method ie. If going with solder, then the quality and standard of the solder / soldering may come into play.
The material / fit of the connector also may play a part eg Whether Gold / Silver / Copper / Brass / Rhodium coated.
I think you are better with a quality factory termination than a DIY fitting with a grub screw, unless very handy with a soldering iron and use the right solder.
Bare wire is great but more fiddley, as care has to be taken with the connection and re-done if signs of corrosion.
I have heard better quality terminations make a difference.
Benedict_Arnold
661
My buddy from Butt-Fork, Louisiana, name of Boudreaux, tried "whittlin' some outta pecan wood" ....
They sure made a difference:rofl:
drummerman
540
If you are the kind of person that likes nicely finished things ... terminate. I use bananas without the plastic cover, solder and shrink wrap for a neat finish.
I internally rewired my speakers and use leaded solder on the bass/mid drivers (copper cable) and silver content solder on the tweeters (silver plated copper cable).
regards
lindsayt
16
My Kylie Minogue CD's are fun to listen to. Well recorded, well produced pop songs.
It's quite possible that the plugs are making more difference than the cables in some bake-offs.
With mains cables the 3 pin plug, fuse and the IEC connector may well be making more difference than the cable itself.
camcroft
938
575
19,770
images
I should be so lucky.lucky.lucky.lucky.............
Benedict_Arnold
661
No doubt they are. But I, for one, would rather be forced to slide naked down the rusty edge of a sheet of old corrugated iron using my manly parts as brakes than have to listen to them.
I agree. That's why I posed the question. Which is better or does it make ****er-all difference?
That's you off the WHF Christmas card list :)
busb
90
12
I'm with Lindsey here. I've a single or two that are well-recorded & well-crafted. Maybe I'm not such a music snob as I thought!
k77stan
24
6
18,525
i use solderless nakamichi bananas from e.b. 8 of them for less than a tenner..not bad at all..my partner wouldnt even dream to put a kylie cd in my player-she knows it will start skipping.. :shame:
Benedict_Arnold
661
I once skipped a Blackberry across Lake Ponchatrain (that's just north and east of New Orleans in case you didn't know). I got seven bounces....
k77stan
24
6
18,525
try harder mate,should be doing better than this :doh:
MajorFubar
690
8
Although I use banana-plugs for convienience, I remain unconvinced that adding another unnecessary component between the cross-over and the speaker-cable will ever add anything positive to the sound. Personally I doubt I'd hear a difference either way, but clamping the bare wire to the terminal at least seems to be one step closer to ideal.
Vizzage
14
So you only listen through one speaker? ;-)
