OK more of an observation than anything else, but why are most cables for connecting ipod to amplifier 3.5mm to Phono connections?
Even cables costing £40.00 like the iChord utilise the 3.5mm jack rather than the connection at the bottom for charging or synching the ipod. This seems silly as the output is via the headphone connection and is therefore limited sound output...i.e. i need to have the ipod volumd turned all the way up and then my amp volume turned virtually to 12 oclock to get anywhere near decent volume output.
The only cable I have seen that bypasses the volume control is the Russ Andrews one and it's only 20cm long though.
Surely if I use a dock and then connect the interconnect into the back of the dock that is just another connection to the loop... i.e. iPod to dock, dock to interconnect and then interconnect to amp??
Just seems weird to me that's all
