interconnects a question of brands.
nads
886
238
19,270
OK source to Pre amp/integrated are Tara labs spectrum 2a's with Tara lab RCS jumpers from pre to main in the integrated. but for the pre out to the power ampi have a supra EEF-1 Ok the second amp is powering the bass while the integreated is doing the upper ranges on the 703's But i was wondering about the cables.. would you go tara labs to replace the Supra? i have no issues with the sound as such but i wonder if anyone had a comparative test of the two brands?
I reckon pre-power you would struggle to tell the difference. I use same brand / cable across electronics so don't follow this, but in all honesty I'd say don't worry about it.
nads
886
238
19,270
not worried just interested.
and i will be buying at least one new interconnect when the turntable arrives.
so it could be perceived more of a what is the difference between the sound of the of the brands?
i suppose i could change the config. to one amp bi/wired and switch some cables in and out to see. But as with most things i love to hear other thoughts idea and horror stories ;)
