Improving my system on a budget
System:
Samsung LE40A786R2FX
Samsung DVD SR275 (Due to upgrade to Sony BDP-S360)
Xbox360
Cambridge Audio Azur 540R V2
Front Speakers: Tannoy Mercury M2.5
Centre Speaker: Kef Cresta 20c
Rear Speakers: Gale 3010 (not the greatest in the World)
Sub Woofer: Mordaunt Short Alumni 9
Cables:
2x Van Den Hul Flat HDMI
1x Atlas Optical cable
Cambridge Audio Sub-Link
Cambridge Audio Symphony 400 (Front & Centre Speakers)
Cambridge Audio Symphony 300 (Rear Surround Speakers)
I'm after some reasonably priced upgrades that'll give my system a bit more clout,
Any ideas?
What exactly are you looking for in terms of an 'upgrade'? Looking at your kit, I think your speaker system is a serious mis-match with each other. Next is your receiver.
You have a reasonably good sub-woofer - I would keep that and get rid of the rest.
What exactly is your budget?
I just want to improve the overall sound quality, I think I'm pretty much set Visually, (with the exception of Blu-Ray, but thats nearly sorted)
I'm thinking around £450 on Speakers, maybe keep the centre speaker that seems to be the best of the 5 sound quality wise,
Probably £350-400 on an amp, don't really want to use 6.1 or 7.1 etc at the moment as although I have a huge living room, there is quite a lot of furniture in it, & we have several doors and arches leading into it, so minimal speakers with maximum effect is what I'm looking for, plus something with an acceptable Hifi ability wouldn't be a bad thing, (It seems newer equipment is better at this than it used to be after a few demos earlier in the year)
For your budget, you must consider the new Q Acoustics 2000 5.1 Home Cinema speaker package, which can now be had for £495.00 (£550.00 original price) - rated 5 **** by WHF.
The Sony STR-DH800 Home Cinema Receiver would be the ideal choice at £279.95 - rated 5 *** by WHF & Best Home Cinema Amplifier up to £300.00 WHF Awards 2009.
Both will work very well with each other. Sorted.
3 I'm looking at for front speakers are:
Mordaunt Short Aviano 1
Mordaunt Short Mezzo 1
Kef IQ3
Rears:
All out of ideas, but something with a small housing due to their positioning,
AV Reciever:
Sony STRDN1000
Onkyo TXSR607
Any views?
I'm not a massive fan of having Satelite speakers at the front, I have some awesome Optimum speaker stands that set me back £175, so I'm looking to make the best of them if possible,
Sony STRDH800 is a nice idea, it's definately going to get an audition at the next oppertunity.
