Impact of USB to COAX Adapter on Sampling Rate
107MHz
I have a Parasound P5 pre-amp that has an integrated Burr-Brown PCM1798 DAC and would like to stream music to it from my Windows 10 PC which is ~ 40' away.
I would like to use the P5 DAC's COAX input which supports 192kHz/24 bit, however my PC only has USB ports where the P5 DAC limits USB input to 96kHz/24 bit.
If I connect the PC to a COAX cable via a USB to stereo-COAX adapter, will the connection be at 96 or 192 kHz?
