AEJim
Oh it goes from bad to worse - Missus was still in bed so I thought I'd at least try to get an initial reading off the plasma to see what it measures like as standard. Unplugged the PS3 from the man room, bit of a hassle due to it being on top of a bookcase, neatly wired into the projector... Get it in the living room, wire it up, no picture - ah yes, it's set for component and I'm not lifting the TV off the wall myself to try and access those inputs... Back on the projector, having made enough noise to wake the other half upstairs and knocking my projector all out of alignment in the process, only to realise the PS3 is a very irritating device - I want to switch to HDMI, but when I do so it does that lovely check the blank screen process, which of course I can't see, so don't know what to press, so can't alter it. What if you only had say a component source (like the projector I have), how would you change it from the initial HDMI settings? One of those mornings... (oh, and I wanted the PS3 to run patterns, as I have a HD disk, I know I have to use the laptop software on the Eye One
Max, if it helps I'm sure my black levels have actually improved over time - it's like the pro calibrator I quoted the pics from said, in direct comparison to his G20, yes the G20 had deeper blacks, but the 350 had better motion handling, litte posterisation/banding and better colours with more "pop". He classed them as even but each having benefits depending on the material, I hate poor motion handling so that swayed it for me
