How to Terminate QED Revelation
Nabs
8
I have some of this wire and need to terminate it. I already have banana plugs (screw fit) from my previous qed silver anniversary but was wondering if anyone had any ideas of the best way to terminate, when I look at the cable there are silver strands and rubbery strands around a plastic core, do i simply separate the silver stands out push them into the banana and cut the rest off?
Help would be appreciated
Proper QED Airlocs are best, but they're quite dear to fit, granted. If you want to reuse your existing ones, you need to strip the outer sheath and also cut back the central plastic core, then twist the strands together.
It is not that easy I am afraid.
You have to remove the outer sheath, then strip each individual wires under the outer sheath. It takes ages to do unless you have a wire stripper as used on electrical cables.
Good luck....
