How to replace a Linn Kairn
Tecumsea
8
My Kairn has just given up and power supplies are no longer available. I have an LK140 amp , lp12 with Ekos arm and MC cartridge driving Naim CD5! and Lynn Majik 140 speakers.
What do I replace the Kairn with? -most new preamps if they have phono stage it is MM-so do I buy an integrated amp and add a seperate phono MC stage like the Rega or is there an alternative amp with MC phono stage?
I'm UK based, there is a recapped and new Power supply Kairn on Ebay, but with linn no longer supplying the parts this could be a problem again in a few months time.
My budget if needed is about £3k
I mainly play cd's but would like to keep the LP12 if possible
Suggestions would be appreciated.
So is buying a second-hand Linn Kairn out of the question?
If it is then a different preamp and a step up transformer for your MC might be the answer.
That or the Musical Fidelity M6S PRE, yours for £1599
Thanks for the prompt reply, I'm not against buying a second hand Kairn but it is a risky strategy given the lack of spare parts. If there was an alternative I would probably use modern replacements. Would I be able to link my LK140 Amp to a modern pre-amp such as Naim Nait XS3 or XS5?
See my previous post, I have added to it
Thanks for the tip on Musical Fidelity, I'm going to get a demo of the new M6si integrated amp, it seems to be getting good reviews
If you only really need a preamp, the new Neutron from Leema might be worth considering for £1500.
13 inputs, including MC, according to the Hi-Fi News review.
(Matching Graviton power amp also £1500, but package price for both £2800....minus any other discount you might negotiate)
