I want to introduce a subwoofer to my stereo setup for use as a 2.1 when watching films. Just need a quick check with you guys to see if I’ve got a few connection issues right.
Current setup:
Rotel RA-02 Integrated Amp being used as Pre-amp
Rotel RB-06 Power Amp
Q Acoustics Concept 20 Speakers (connected to Power Amp)
The ‘pre-outs’ on my Integrated are in use supplying the power amp.
The speaker terminals on the integrated are not in use, as the speakers are connected to the power amp.
If I purchased a Q Acoustics 2070Si Subwoofer (which has high level connection) I think I could use the un-used speaker terminals on the integrated to connect the subwoofer – am I correct?
My main concern is that the speakers are being powered by a 70W poweramp, and the subwoofer would be getting its signal from a 40W amplifier – would this be an issue in terms of integration with the stereo speakers?
Current setup:
