How Long Do Speakers Take To Sound Good
Dom
989
299
19,270
So, how long do you think it takes for speakers to "break in"? Weeks, months or years.
It seems like one of these rare hobbies that actually reward you for being patient.
gasolin
1,458
291
19,570
Some say they don't change, some say they do
With how much i play music i would say max 2 weeks, some say 50-100 hours like BØRRESEN
All new high-quality loudspeakers need a certain burn-in period. As BØRRESEN loudspeakers use long-stroke bass driver with natural rubber surrounds, the loudspeakers need at least 50 - 100 hours of actual music playing at a moderate sound level.
abacus
837
530
19,770
Pink noise is your friend here, place the speakers 1m apart facing each other, connect one of the speakers out of phase, feed a mono signal to the speakers, (Pink noise is ideal as it covers all frequency bands appropriately) you will then be able to turn up the volume loud (Just be careful not to overdrive the amp and speakers) without interfering with the neighbours as the sound cancellation will keep the sound low. (This is basically how noise cancelling works) NOTE: The volume from the speakers will not be low, it will only appear to be.
As to the amount of time, check in the manual as it is normally specified, if not then the manufacture has probably already done it at the factory so you can just sit back and enjoy.
Bill
newlash09
220
45
10,820
I have been told it depends on the individual drivers. With berrilium tweeters taking up to 500 hours to finally settle in :)
chris661
191
119
270
I had some fairly esoteric full-range drivers a while ago that took around 100 hours for most of the changes to settle down.
I put them face-to-face in close proximity (closer the better - cancellation improves if they're close) and wired one of them backwards. Put something fairly bass-heavy on (got the cones moving a good amount) and left them for a day at a time while I was out.
The first week of that, the changes were obvious. After the second week, the differences were much more subtle.
When it comes to PA drivers, I find the first kick drum hit at >1000w per driver will tend to break them in pretty quickly.
Chris
Dom
989
299
19,270
My speakers just recently sounded better after a short high volume session, and thought I would create a post asking people's views...
I appreciate your view!
ASK THE COMMUNITY
