Infiniteloop said:lindsayt said:Really? What if you're, for example, a one man band, making clones of existing classic SET valve amps? Do you really expect someone like that to pay much attention to the "design"?Infiniteloop said:As a designer, I feel there is no excuse for poor design at any price point...
Or what if you think the route to overall best sound in speakers, without getting too over the top in size and price, is to mate a 15" bass driver with a compression driven midrange with a horn that's shaped to help in-room dispersion? How on earth do you design such a speaker to look good? The best you can do is cover the ugliest bits with some cloth or foam.
Sometimes in hi-fi it's acceptable for form to follow function.
Form should follow function in almost all good design:
A lone SET Amp maker should pay attention to the design of the curcuit layout, how the components fit inside the case, how the wiring is soldered and which components to use. These are all design considerations and affect both the sound quality and reliability.
If the design of a speaker is thought through properly, the aesthetics should look after themselves. Bass driver, compression driver and a horn - PMC manage to pull all that together very successfully.
Which model pmc uses horn and compression drivers??
