bigboss said:
buzz_lightclick said:
gel said:
bigboss said:
Buy why LX81??? When did you buy that? I thought you had LX71.
No, I had the 81 all along I had the blu Ray player the 71. Just bought one amp the 3050 Yamaha.
why did you go for the Yamaha over the Pioneer SC-LX89? It will sound very different to your current amp!
gel said:
I wanted to hear what the Yamaha sounded like.
Besides, the Yamaha is £400 cheaper.
That's because its replacement, the RX-A3060 is imminent. If Gel had waited a bit longer he may have been able to get the 3050 for less. Or he could have waited for the 3060 to get the newer tech.
http://www.sevenoakssoundandvision.co.uk/p-27763-yam-rxa3060-blk.aspx
There's nothing new in the "newer tech":
http://faq.yamaha.com/us/en/article/audio-visual/aventage/rx-a3060_u/110...
Yamaha RX-A3050 belongs to the same generation as Pioneer LX89.
Your article points to a number of differences, a new 64 bit precision equalizer being one of them as well as a wider subwoofer EQ range.
I never said the 3050 was a different gen to the LX89, I was pointing out the 3060 is imminent, hence there will be deals to be had on the outgoing 3050. The LX89 will be replaced in a few months too, but it will be in reality an Onkyo amp from now on, as you know.
I will be interested to read what Gel thinks of the 3050, it's quite a change of heart given he was looking for a Pioneer Susano only last week.
