How do you play this on my TV?
And Sky and Blu-Ray looks amazing and 3D, 4K just don't look right. It should be brighter than Sky. I will tell you what this TV looks nothing like the flat LG and they are both suppose to have the same panel!
gel said:
The_Lhc said:
Panasonic have already told you that the hdr update is already on your TV.
Yep, but I don't think they're right according to people on AV. I don't know what to think?
Surely the TV has a means of checking which firmware version it's running, and downloading any updates it might need using its network connection? Would've thought doing that would ensure it was as up to date as possible, while perhaps also allowing you to set it to check automatically for future updates.
Yep, and it's upto date.
