nirvy111 said:
			I think this is more a case of mis-match rather then mis-use, maybe a bit of both. The NAD d3020 is only 30 watts per channel and the 2020i aren't the most efficient speakers at 6 ohm 88db, combined this with playing at high volumes and the speakers got fried, two pair to be exact. There's no reason why the q acoustics can't safely play as loud as the MA bx2's or any other speakers, if he had a more poweful amp, a 100 watts per channel say, the speakers probably would have been o.k.
Sorry but I doubt it. Even if I agree interfacing a poor quality under power amp and crank the volume at 10 out of 10, you could maybe damage some poor speakers. Then this wasn't the case: desk testing in NAD lab of my D 3020 proved it can safely provide 42 Watt per channel on 8 Ohm with practically no distortion and 67 Watt per channel on 4 Ohm with neglgible distortion, quietly neither.
Q Acoustics 2020i seller had this data from me in his hands, probably becouse he will use it to have Q Acoustics speakers he exchanged to me with another brand repaired under warrantly. If he exchanged two pairs of my speakers under warrantly it admitted it was Q Acoustics fault like reading my OP it surely was.
And, related to system matching, it is totally reasonable match a classy amp (totally NOT underpowered) with speakers rated for a 25-100 Watt amp. Q Acoustics 2020i state 25-100 Watt amp and it doesn't say in any point "please do not turn up the volume becouse if you do it, I will die".
And related with the first pair of speakers, they never broke like the second pair: they just used to crank on bass at high volume. So believe me, thank you for your opinion, then there is no mis-use or mis-match in what happened to me, everything should had been optimal, if it wasn't the two pairs of Q Acoustics 2020i I had in my hands proved to be fragile piece of hardware components.
Even touching the MA BX2, even look at them, you feel a much more stronger type of speaker, something solid, with his metallic parts. And they proved to me to be a completely different pair of speakers, they have no problem at all, they are SOLID.
Someone had asked here if amp sellers could introduce something potentially stopping electrical distortion: they always did it, my NAD D 3020 goes into protection for every little mis-use he can detect. Example, if you move a speaker during playin, it suddenly shut hisself down for protection. So they always have this mechanism.
It is speakers vendors that should calibrate a speaker better, first of all they should respect them own made specs they declare on them sheets (and it didn't in my 2020i case).
