Home AV Direct, Yamaha RX-V673 & Q Acoustics Q7000 package
Pending being able to audition the above receiver/speakers combo, I am looking to buy these this weekend.
I have a couple of questions I was hoping someone might be able to answer,
Firstly does anyone have any experience of using home av direct and are they a decent outfit? http://homeavdirect.co.uk/
Plus secondly, as i was planning to audition the setup in a richer sounds, (and would therefore feel better about buying from there on the basis that they've actually provided the facilities to listen to the kit,) does anyone know whether they will match the package price offered online (on the basis that it's a deal on the 2 items)?
The package is £979 with homeavdirect. the 2 at richer sounds would be £494 + £720 = £1214
Anyone's opinion on the merits of the set up itself would of course be appreciated.
f1only
278
No not personally
I would give your local Richer Sounds a ring & ask if they will price match it, but be aware they will only do this if home av direct have it in stock.
Sorry, the setup i could not give an opinion on & i would have to audition it first to do that. Good luck with it
Regards...
simonali
186
51
18,620
Seems a bit naughty to audition the kit at one store and buy from another. I assume you've not seen this...? http://www.richersounds.com/package/home-cinema/1-box-home-cinema-systems/pah01869
